A right click on a note in the notes tree opens a context menu with the option "Tags".
Changing the tags of a note + closing the window "Select Tags" does not update the tags field at the buttom of the note.
It's necessary to select another note and to switch back that the modification of the tags gets visible.
Essential Pim 9.8 Portable
Notes Modul: Editing Tags via the Context Menu of the Notes Tree
- Has thanked: 1418 times
Re: Notes Modul: Editing Tags via the Context Menu of the Notes Tree
Confirm the problem, will be fixed in the next version, thanks!
