Hi, I've got a client running EPIM v8.53.1/Firebird 2.5.7 on a small 3 user network. To upgrade them to v9 is there anything special to do? If I run the installer on the server will that upgrade firebird as well or does that have to be done a different way?
Thanks,
Scott...
Upgrade to v9
Re: Upgrade to v9
The installer will update Firebird if the newer version was included in it. As for the clients update, simply install the new version over and make sure you first connect to the network database as a SYSDBA user in order to update it to the latest version.
