When I copy a text from a Word document and paste it into the email, irregular blank spaces are swallowed. As a result, "We would like to add these" suddenly becomes "Wewould like to add these" in the email. The email is set to Rich Text.
How can this be remedied?
Blank spaces are swallowed
Re: Blank spaces are swallowed
Will have a look at this. Meanwhile, use the "paste as plain text" feature, that should preserve blank spaces.
- Has thanked: 14 times
- Been thanked: 24 times
I have a .jpg of the same from 10/11/18, but never knew the Fix.
Just Opened a New Email to Send and copied from a Word .docx and Pasted to email .... Results below.....BOLD hi-lights From ME ...
Thesimplest way to search is to use the global search bar at the top of everypage. This will allow you to search all available content types. If you want touse a more advanced search, you can use the AdvancedSearch option.
AdvancedSearch Operators
Thereare various search operators that will work when you search (you can of courseuse multiple operators in a single query)...
AND
The AND operator allows you to search for documents thatmust containmultiple keywords.
AND
EPIM PRO LIFE 11.8.4 - Win 10 Pro - 22H2 --- ESET EIS Prem - Mbam Prem - Diskeeper Pro '15 - Macrium Pd v8
