I have created an additional Birth field for one of my contacts. I would like to see the birthdates of all his family members shown in the calendar.
I choose the date type of filed, but it doesn't appear in the calendar view.
Any ideas?
Additional birthdate field
Re: Additional birthdate field
Thank you for your answer!
Unfortunately, it doesn't work.
I have opened the Edit fields. It is no sense to select the Birthdate (Date) field since this field is already used for the main contact and works just fine. I have created a custom field named Daniel, the field's type is Date. No Change Filed button found.
I have Essential PIM Pro Portable 9.8, Windows 10.
- Has thanked: 26 times
- Been thanked: 92 times
For the date to appear in the calendar you have to check the checkboxes on your second screenshot.
You can also change the category there to Birthday (or to something else).
