Wrong indent after links in Day/Week View (small visual issue)
Keldi
Has thanked: 26 times
Been thanked: 92 times
Post by Keldi »
Windows 10 Pro 20H2 build 19042.985, EssentialPIM Pro Portable 9.9
Some characters cause a small visual issue in Calendar > Day and Calendar > Week (other Calendar views and Today module are fine):
there is wrong space between the contact's name and ". Birthday" in the automatically created Birthday appointments.
For example, create contacts with the same birthday date and with First Names:
Code: Select all
Hello
Hello :))))))))))
Hello :))))))))))))))))))))
Hello :))))))))))))))))))))))))))))))))))))))))
Hello :))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))
Switch to the Calendar > Day. The more times the 'problematic' character is used, the more away from the right position the ". Birthday" is moved:
It's only visual. If I click to rename, all's good:
In the attachments is a test CSV file (contact names with characters only of some Unicode ranges). I generated it to see whether the issue was with the punctuation, and I see that it's not.
Just some examples.
Some Basic Latin letters are fine, and some not:
Some punctuation is fine, and some not:
Some symbols cause some weird things, while others are fine:
An afterthought:
It's not only the Birthday appointments, but any appointments (or 'Show in Calendar' tasks) with a link and a text after it, when there are 'problematic' characters in the link's name.
Day's view have an indent while the Edit window shows that there is just one space between the link and the text:
epim9.9_test_contact_birthday.zip
(5.89 KiB) Downloaded 77 times
Has thanked: 1411 times
Been thanked: 984 times
Re: Wrong indent after links in Day/Week View (small visual issue)
Thanks, Keldi for the very detailed description of the issue. Will attempt to fix it in the next EPIM's update.
