öäü
Haldex
Has thanked: 25 times
Been thanked: 5 times
öäü
Post by Haldex »
Since the update to 9.9, ö,ä and ü are displayed as � in the email. Where can these be set correctly again?
a8907433
Been thanked: 170 times
Re: öäü
Post by a8907433 »
For me, nothing changed with German Umlautes. It works in sent and received mails. Did you change the font? (EPIM V9.9)
Haldex
Re: öäü
Post by Haldex »
I did just update and then the incoming E-Mails show this behaviour.
a8907433
Re: öäü
Post by a8907433 »
What about old emails? Perhaps the problem originates at the sender? So, it is not a problem in EPIM, but the new mails were sent in the wrong encoding?
Haldex
Re: öäü
Post by Haldex »
It is the same with some old emails. But not with every email and not from every sender. By changing the encoding, it is possible to eliminate the wrong letters. By the way, everything is fine in Outlookor in Postbox.
Re: öäü
Please export couple of problematic emails into EML files and forward to us. Will check what's mentioned as encoding in their headers.
Haldex
Re: öäü
Post by Haldex »
I must say now, that in general the emails are coming in in a god way. I see now, that there ist one ore two senders. So no big problem.
Re: öäü
Thanks for the sample emails. I think this has already been fixed in the internal builds. Would you like to give it a try? If so, will forward you a download link.
Haldex
Re: öäü
Post by Haldex »
Yes please send it to me!
Re: öäü
All right, please check your PM.
eggie
Re: öäü
Post by eggie »
I have the same issue since upgrading to 9.9.
2 senders so far affected. Can you send me the fix, please?
Thank you
eggie
Re: öäü
Sure thing! Instructions sent via PM. Thanks.
Haldex
Re: öäü
Post by Haldex »
OK, there is not yet the end. Again a email from a sender, which stay on Unicode 8 and therefor wrong öäü! But with western it is ok!
Haldex
Re: öäü
Post by Haldex »
This problem annoys me again and again. I cannot tell my email senders how to write an email. So it would be good if I could set the default encoding.
At the moment, Unicode UTF8 is displayed. But in these emails where öäü are not displayed correctly, I always have to switch to an encoding with WESTERN.
Is it not possible to change this permanently?
Re: öäü
We'd need to get couple of sample emails in order to check this again. Thanks.
