Search results incorrect
Mel
Has thanked: 9 times
Been thanked: 9 times
Post by Mel »
Problem:
Search for items with a simple tag "ToDo".
Scenario 1:
Advanced Search > Search in fields: Tags
Search for: ToDo
Result: Two notes (correct find), and a long list of irrelevant e-mails wit no tags assigned.
Scenario 2:
Advanced Search > Search in fields: Subject, body, and tags
Search for: ToDo
Result: Two notes that I'm looking for, no extra e-mails.
Why the results are incorrect when search is limited to the Tags field?
(EPIM 9.8 portable pro)
-- Mariusz
Has thanked: 1411 times
Been thanked: 984 times
Re: Search results incorrect
This seems like a bug still present even in EPIM 9.9. Will fix it in the next update. Thanks!
