EPIM Sever Sync errors
These happen very randomly, I just turned on extensive logging and am waiting for them to happen again to post an error log, in the mean time I thought I'd post the screen shots.
Re: EPIM Sever Sync errors
here's the contetns of the log file for one of them, which isn't much more than the screenshot:
EssentialPIM Pro Portable 9.9 6/11/2021 2:54 AM
13:14:19.731 3452 Start Sync EPIM Server (A:\NetStorage\BookSync.epim)
13:14:23.372 3452 List index out of bounds (63)
Class: TStringList
Class: TStringList
Thanks, will have a look at that!
This seems like a problem with the particular database. I'd ask you to make a copy of it, delete all the sensitive data from the created copy and then forward the file to us, will check what's causing the issues. Thanks!
After updating to 9.9.6 it hasn't happened again. If it does though I'll upload a DB.
Good to know, thanks for letting us know. Will keep an eye on the topic.
