Tags Explorer and keyboard
Keldi
Has thanked: 26 times
Been thanked: 92 times
Post by Keldi »
Windows 10 Pro 20H2 build 19042.985, EssentialPIM Pro Portable 9.9
In the Tags Explorer:
I.
1. Search for a tag in Search Tags.
2. Shift+Tab twice - the focus is on the list with tags.
3. Visually we see only the found tag/tags, but with the keyboard you have to use Arrow Up/Down to go through all other tags, as if the search wasn't done.
Example (an animated GIF in the attachments):
First search: tag5 (in the list of tags from tag1 to tag9).
Shift+Tab twice - the focus is on the invisible tag1 now and nothing is in the list of found items.
Arrow Down 4 times - the focus is on tag5 and the results are showed (first Down - focus on the invisible tag2, second - tag3, third - tag4, fourth - the searched tag5).
Second search: Tab twice to return to Search Tags, search for tag2.
Shift+Tab twice - the focus is on the invisible previously searched tag5.
Arrow Up 3 times (to go through invisible tag4 and tag3) to see the results for searched tag 2.
II.
1. Search for something in Find.
2. Tab, Arrow Down - the focus is on the found item.
3. [Enter] does nothing (have to use Shift+F10, Arrow Down, Enter to access "Details...")
Re: Tags Explorer and keyboard
Thanks for the info, will fix.
