EPIM server sync note icon issues
S_Belle
Been thanked: 4 times
Post by S_Belle »
I'm trying to use the new EPIM server sync, and everything seems to be working except that some notes that are set to have no icon randomly get changed to a folder icon after syncing.
Re: EPIM server sync note icon issues
Is that a one-time change or it keeps changing even after you modify notes to not contain any icons again? And does it happen with a set of particular notes or this behavior is random? Also, does it happen each time or just time to time? Thanks!
S_Belle
Post by S_Belle »
It appears to be quite random, and yo-yo's back and forth.
Some times a note will stay icon less on one computer but have a folder icon on another, than I'll change the folder icon to blank on the other computer sync it over and it becomes a folder on the computer where it was staying blank.
It's almost like the icon IDs are somehow different or getting shuffled around on each computer.
P.s
Both computers are using 9.9.6 and on both I started with a new databases.
MetalDrop
Been thanked: 189 times
Post by MetalDrop »
I report a similar issue and thus have made a video using VNC to show it in action.
Folder icon yo-yo.mp4
(1.03 MiB) Downloaded 84 times
Thanks, will check this out and attempt to fix.
