High CPU usage
KuroTenshi28
Been thanked: 7 times
High CPU usage
Post by KuroTenshi28 »
I am writing to you because I have had an issue for a long. Each time Essential PIM Pro is run, it consumes about 35% of CPU for at least 10 minutes. I have a SSD and an I5 CPU (3.5 ghz). I tried to optimize the database but it doesn't solve the issue.
Is there a way to solve this ?
Thank you
Re: High CPU usage
Please post a screenshot of the Database Management dialog window, accessible through the File menu.
KuroTenshi28
Re: High CPU usage
Here:
Re: High CPU usage
You may try optimizing the number of events if you don't need them all. For example, archive the legacy ones using EPIM Archiver.
KuroTenshi28
Re: High CPU usage
WOW ! I was looking everywhere for this kind of software ! I even bought GCalToolkit, that doesn't work well...
Problem solved. I wanted to remove duplicates (due to synchros) for so long !
Thank you !
