[Fixed]. Odd buggy behaviour: Appointment creation by dragging still sets default time 15 min.
Trinitylab
Has thanked: 16 times
Been thanked: 41 times
Post by Trinitylab »
The latest Business, 995.
But the problem persisted previously.
Steps
set default Appointment time in Calendar to 15 min.,
save it as default,
in Week view Calendar click and drag for 2 hours in order to create an Appointment,
after release of LMB the appointment window opens,
there is 15 min. length there, instead of 2 hours.
This is not how it should work:
when I had a default (factory) setting of 30 min. per appointment,
each and every time I dragged LMB through calendar to create a longer appointment, I got an expected, dragged, length, not a default 30 min.
Which was logic. Default length is meant for a double click in Calendar, dragging creates custom length of an appointment.
The same should be with 15 min. default.
Cheers.
Re: Odd buggy behaviour: Appointment creation by dragging still sets default time 15 min.
I see your point, will try to improve this behavior in the next update.
Trinitylab
Great, thank you.
Trinitylab
Re: [Fixed]. Odd buggy behaviour: Appointment creation by dragging still sets default time 15 min.
As of 997 seems to be fixed, thanks.
