Major issue:
After the introduction of the "dark themed" Checkboxes, checkbox list no longer copy/past correctly into other programs.
To see what I mean Copy a checkbox list from EPIM and past it into MS word.
Minor issue:
The checkboxes are out of alignment with the other list types, which makes mixed list look really funky.
Checkbox copy/past bug & Checkboxes out of alignment with other lists
Re: Checkbox copy/past bug & Checkboxes out of alignment with other lists
As far as I can see dark themed checkboxes are copied just fine into MS Word. They're dark, though but that's expected?
As for the minor issue, will try to improve in the next update.
