9.9.7 Access Violation on a simple calendar date selection
bgorgnizr
Post by bgorgnizr »
Hello. Before I report the issue with the 9.9.7 update let me commend you for a product that basically has served well. I purchased EssentialPim Pro in 2018, and except for the occasional hiccup with a release here and there, it has functioned for my basic needs.
However, 9.9.7 has yielded what appears to be the most persistent access violation error. I've sent email when it occurs (at least the log that is
preformatted to send to errors@essentialpim.com, which I've had to copy/paste to my browser email client to be able to email).
I've sent two emails this week.
Luckily I had 9.4.1 version of the exe accessible.
I'm using Windows 10 Professional 64 bit.
The full text of the access violation which evidently occurs at the same address has grown in frequency since first reported; all I tried to do today was select 7/26 from the calendar. A Screenshot is attached. P.S. Would it be possible to make previous versions of the exe downloadable? It seems the only option is to download 9.9.7. I guess I'll have to make manual backups.
Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C.
Exception log with detailed tech info. Generated on 7/24/2021 7:39 AM.
Application title: bag.epim - EssentialPIM Pro
Application: EssentialPIM Pro 9.9.7 7/20/2021
Exception message: Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C.
Exception address: 013CBC10
Main thread ID = 11508
Exception thread ID = 11508
Object Logs:
07:38:51.782 SetViewMode 1
07:38:48.587 AppRestore OK
07:20:43.810 AppMinimize OK
07:20:38.747 DBOpen OK
07:20:38.471 SetViewMode OK
07:20:36.235 SetViewMode 0
07:20:35.562 DBOpen
07:39:56.752 MessageEditForm_1 PageControl1 TextTS TWebBrowser
07:39:41.142 ExceptionDialog OkBtn
07:39:40.658 MessageEditForm_1 PageControl1 TextTS TWebBrowser
07:39:27.830 ExceptionDialog OkBtn
07:39:27.137 MessageEditForm_1 PageControl1 TextTS TWebBrowser
07:39:26.417 ExceptionDialog SendBtn
07:39:22.614 ExceptionDialog OkBtn
07:39:22.179 MessageEditForm PageControl1 TextTS TWebBrowser
07:39:19.112 ExceptionDialog OkBtn
07:39:18.625 MessageEditForm PageControl1 TextTS TWebBrowser
Exception stack
Stack list, generated 7/24/2021 7:39 AM
(00FCAC10) [013CBC10]
(0022B25A) [0062C25A]
(0022B2CB) [0062C2CB]
(00230442) [00631442]
(0022F843) [00630843]
(011E6B20) [015E7B20]
(01526197) [01927197]
(01526253) [01927253]
(01526B34) [01927B34]
(01539A64) [0193AA64]
Memory: 65397; free 58458
PrevExceptions:
07:39:07.734 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
07:39:18.564 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
07:39:22.096 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
07:39:26.813 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
07:39:40.585 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
07:39:56.678 Access violation at address 013CBC10 in module 'EssentialPIM.exe'. Read of address 0000035C
Updates: 1
Last update: 7/23/2021
-Brandon Guillermo-
Diverse Elements/Chart Your Course
email: info@newcenturywork.com
web: https://newcenturywork.com
Re: 9.9.7 Access Violation on a simple calendar date selection
When does the error occur? Is it reproducible?
Older EssentialPIM Pro versions are available here:
https://essentialpim.zendesk.com/hc/en- ... r-versions
bgorgnizr
Post by bgorgnizr »
Thanks. As described, it occurred by selecting a date while in calendar, immediately after opening. Unfortunately I'm engaged in multiple priorities and need something that won't hinder progress. I'll reinstall the last successful version beyond 9.4.1 and wait for 9.9.8+ release.
-Brandon Guillermo-
We need to be able to reproduce the problem first in order to fix it. So please do the following when time allows:
1. make a copy of your database file
2. open the created copy with EPIM and delete all the important data from it, leaving just unimportant data
3. optimize the database, exit, start again and see if the problem is still there
4. if it is, archive the file it and forward to us
5. we will try to reproduce the issue on our side and fix it
Thanks!
PMSkalsky
Post by PMSkalsky »
Has anything been clarified on this?
I have been an ESSENTIALPIM user for a week. I have the same problem ;(
Should be fixed in the upcoming new 9.10 version. Here's the download link if you wish to try it out a bit earlier before it's released publicly (also already available as an auto update if you're on the Beta update channel):
www.essentialpim.com/download/temp/Esse ... ull910.exe
