EssentialPIM Pro Portable 9.9.7 (but the error first appeared in some previous version)
On switching to the Calendar Table I sometimes get an error about the date being less than minimum of today's_date_here.
I couldn't reproduce it on purpose. All I know is that:
a) the Calendar Table was left with "No filtering" the previous time I was there
b) the error appears on the first switch that day to the Calendar Table (regardless whether the PC was booted up and EPIM opened fresh or the PC was started from the sleep mode and EPIM was running from the day before);
c) after the error I switch to another module and again back to the Calendar Table, and then it all works for that day without any errors;
d) it doesn't happen every day, some days I switch to the Calendar Table and there is no error.
Code: Select all
Exception log with detailed tech info. Generated on 03.08.2021 19:23.
Application title: keldi9.epim - EssentialPIM Pro Portable
Application file: D:\EssentialPIMProPort9\EssentialPIM.exe
Application: EssentialPIM Pro Portable 9.9.7 20.07.2021
Exception class: EDateTimeError
Exception message: Date is less than minimum of 03.08.2021.
Exception address: 005A83FD
Main thread ID = 1468
Exception thread ID = 1468
Object Logs:
19:23:34.654 SetViewMode 1
19:23:23.223 SetViewMode OK
19:23:22.688 SetViewMode 2
19:22:52.807 DBSave OK
19:22:52.454 DBSave
19:20:53.011 DBSave OK
19:20:52.459 DBSave
19:18:52.994 DBSave OK
19:18:52.451 DBSave
19:16:53.070 DBSave OK
19:16:52.449 DBSave
19:14:53.451 AppRestore OK
19:14:52.995 DBSave OK
19:14:52.440 DBSave
19:12:52.978 DBSave OK
19:12:52.436 DBSave
19:10:52.985 DBSave OK
19:10:52.441 DBSave
19:08:53.221 DBSave OK
19:23:23.260 MainForm
19:22:59.842 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
19:22:42.342 ToDoDialog PageControl1 ToDoTS TextMem RichViewEdit
19:22:22.890 ToDoDialog PageControl1 ToDoTS TitleEd RichViewEdit
19:22:14.983 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
19:22:09.848 TaskDialog TagsFrame1 TagsFPan TagEd
19:15:00.237 TaskDialog PageControl1 TaskTS TextMem RichViewEdit
19:14:59.299 TaskDialog PageControl1 TaskTS TitleEd RichViewEdit
18:31:59.296 MainForm FormPan FormPan2 TodayForm Panel2 TasksPan TasksSubForm TasksVT
18:30:28.395 TaskDialog PageControl1 TaskTS TextMem RichViewEdit
Memory: 16319; free 8302
Updates: 0
Last update: 31.01.2021
