Relate Email - Help Request
OMNI
Post by OMNI »
I use Tasks for "Projects" and relate items to the appropriate "Project" - relating email seems to be too time consuming - Is there another method?
Here's what I do:
- Check inbox - several emails that are in reference to different "Projects".
- Open "Project" and click on Related items tab - Select Add New - select mail module to filter out other items - select desired message to hyperlink - click OK - Click OK on "Project" - select mail module - drag and drop linked email to Archive Folder (created to keep inbox uncluttered) - repeat process for remaining emails that need to be linked.
AND
This is only half the battle - what about sent mail that pertains to a "Project"
Hopefully I am missing a procedure or feature that will streamline this process? Looking for suggestions.............
OMNI
Re: Relate Email - Help Request
I'd use tags - would be faster and you can create message rules for emails to automatically assign specific tags to the messages that fit the set criteria.
As for the related items - do you see any ways your workflow could be improved by changing something in the app?
Haldex
Has thanked: 25 times
Been thanked: 5 times
Post by Haldex »
What if you used tags? Tags work for both outgoing and incoming emails. Wouldn't that simplify the whole selection process?
OMNI
Post by OMNI »
I will give the tags a try - all projects are numbered - so it should work
OMNI
