I have just installed the latest version of epim (9.10.5) today.
When I click on the notes, I get the following error message. I can then only close the programme via the Task Manager.
Unfortunately, nothing happens when I click on the "Send" or "Details" buttons.
Does anyone know the problem?
Thank you and greetings
Error Notes Module
- Has thanked: 1407 times
- Been thanked: 977 times
Re: Error Notes Module
We were able to reproduce the problem. Working on it. Meanwhile, as a workaround solution you can sync your data over to the new DB using EPIM Synchronizer. You will be able to get back access to your notes then.
Fixed in the EPIM 9.10.6, please update. Thanks!
