I think i found a bug on EPIM 9.10.5. I am on win10.
Created a task and added a child. On the tasks main window, on the top were you can check which properties you want to see, i turned on status so i could lock the task with a click. When i lock a task with a child it just get deleted and it doesn't even go to the trash. It just disappears.
If i do CTRL-Z only the main/parent task shows up, all the rest just get deleted with no trace not even in the trash.
Screenshot attached.
Tasks child bug
- Has thanked: 1406 times
- Been thanked: 977 times
Re: Tasks child bug
Please check if you have the "Show private items" option enabled by clicking on View menu.
- Has thanked: 28 times
- Been thanked: 6 times
Re: Tasks child bug
*insert Homer Simpson hinding in the bushes here*
Yeah.. i never used it before, and i was configuring a new database and i thought that the lock icon was to lock it in read only mode....
Thank you for enlightening me.
Re: Tasks child bug
Read-only is marked with a different icon Although, click on that field should probably allow you to cycle through all the statuses, read-only included. Will improve this in the future versions. Thanks!
