Essentil 9.10.7 bug with dropbox
Denisov
Has thanked: 13 times
Been thanked: 33 times
Post by Denisov »
I am connected to the internet. Whenever I save the database in Dropbox, it keeps giving me connection error. How should I do? With the previous version (9.10.6) it was perfect
Thank you
Denis
Best regard / Mit freundlichen Grüßen
Has thanked: 1411 times
Been thanked: 984 times
Re: Essentil 9.10.7 bug with dropbox
What precisely does the error message say? Please also forward us the log file.
Denisov
Post by Denisov »
That here message!
Thanks, would appreciate if you could also forward us the log file so that we could check what's going on behind the scenes.
Denisov
Post by Denisov »
admin wrote: Sun Oct 24, 2021 10:31 am Thanks, would appreciate if you could also forward us the log file so that we could check what's going on behind the scenes.
How do I create the log file? Thanks
You don't need to create it but get it from here: Tools->Options->Synchronization, Browse... and then forward to us. Thanks!
Denisov
Post by Denisov »
Ok, Thank!
Here is the dropbox log file!
Dropbox_2021_10_26_21_18_04.log
(37.46 KiB) Downloaded 77 times
Thanks, sync your database over to the new one using EPIM Synchronizer, that should fix the problem (which is with the sync token length changed by Dropbox recently).
