contacts sync using google to samsung s2 - android
ikkieik
Post by ikkieik »
would to have my contacts synchronized with my samsung s2 - android , using google to transfer from desktop to mobile.
on both google and the samsung s2 i am loosing contact info. as far as i can see the info from new created contact fields is gone.
as example for some accounts i have created within the contact 2 new fields containing email info, when synchronizing those new fields and the info are gone
on the google and android accounts. they still remain on my desktop.
any suggestions to have those additional field synchronized to my android ?
thanks for your help
i
Re: contacts sync using google to samsung s2 - android
The problem here is that EssentialPIM adds its email fields into Google Contacts as custom and not as special email fields. Therefore, these custom fields aren't considered as being email ones by Android and that's why it looses them during Android<->Google Contacts synchronization.. Will try to fix this issue in the next release. Thanks for letting us know about it.
keiooz
Post by keiooz »
Does this fix already been made?
Works like a charm!! Image
Yes, the fix is available in the latest Beta version of EssentialPIM 5.0.
