When synching with Outlook and Google Calendars, my system is "always" creating duplicates, triplicates, etc. whenever the synchronization occurs. I've ended up having to take off the automatic synchronization because of this problem. Is there a way to synchronize without causing these duplicates? I have used the tool to remove them but prior to that, I ended up completely messing up my calendar from this because I had NUMEROUS entries on ALL synchronized calendars. There should be something in the synchronization that detects the items ALREADY ON THE CALENDAR and take into account whether it's been modified or not and place the most current item on the calendar or NOT place another item on the calendar if it's the same as an existing one.
Regards,
Susan Caughey
scaughey@scottsdaleaz.gov
Systems Integrator
Scottsdale Police Department
480-312-5856
EPIM Synchronization
Re: EPIM Synchronization
There should not be any duplicates. Usually the reason for this are addons by other manufacturers that change the items that causes EPIM to generate duplicates. For a test, please disable any addons that have access to your calendars.
