Google Calendar Sync Not Working Properly
pimuser
Post by pimuser »
I am VERY disappointed in EPIM's lack of proper support for Google Calendar Sync - it's shameful really since it's an advertised feature that seems to work poorly at best.
That said, let's begin with just one simple example where syncing fails. Create a repeating event on Google (via Web), then sync EPIM. Now delete one single instance of the repeated event on Google (via Web), then sync EPIM again. The deleted instance is NOT deleted from EPIM. What gives?
pimuser
Re: Google Calendar Sync Not Working Properly
Post by pimuser »
Wow, timely response!
Been thanked: 363 times
indeed, synchronization of exclusion of repeating events is tricky and we are working on improving it.
