How to sync Outlook 2002/XP with EssentialPIM Pro Business Edition 7.2?
logies
Has thanked: 15 times
Post by logies » Mon Jan 02, 2017 1:03 pm
Hello, I would like to migrate a complex installation of Outlook 2002 (VM of XP Prof with a terminal server from Thinstuff, Public Sharefolder for public outlook folders (also based on a *.pst), Mailenable, GPGRelay) with about 6 *.pst of 6 people to EssentialPIM Pro Business Edition 7.2. My test period started yesterday. The *.psts contain thousands of entries of 11 years (especially important are recurrent tasks with links to local files on the terminal server), so copy&paste is not an option. I have installed the server (VM of Win 10 Prof) and client (on the above Win XP) . For testing I added a Google Mailaccount on the client for starting syncing with Outlook. At the moment sync is failing with "Mapi Error: 8004010F. Die DLL-Datei des Informationsdienstes kann nicht gefunden werden." I understand that EPIM 7.2 does not support Outlook 2002 for syncing as I just saw on your website. Might a downgrade help? To which version? How to downgrade? Other solutions?
Michael Logies
logies
Re: How to sync Outlook 2002/XP with EssentialPIM Pro Business Edition 7.2?
Post by logies » Thu Jan 19, 2017 9:17 am
Any hints, how I can migrate my data from *.pst (Outlook 2002) to EPIM?
After rethinking migration: Essential would be the one time import of one *.pst with recurrent tasks, addresses and perhaps email (for email several options are available, I think). I could mail the *.pst to support, if you could convert it.
Thanks!
Michael
MetalDrop
Been thanked: 111 times
Post by MetalDrop » Thu Jan 19, 2017 7:30 pm
I don't use outlook so I can't be of much help, especially as it would seem converting .pst's to something useful seems to usually require buying 3rd party software, but one idea is that since the issue is using too old of a version of outlook you could try making a copy and than upgrading it to a trial versions of outlook from a newer version of office to sync everything across.
Windows 7 64-bit US-ENG & Windows 10 64-bit US-ENG, Intel i7 7700k, 32GB DDR3, Nvidia GTX 970
logies
Post by logies » Fri Jan 20, 2017 9:57 am
Thanks. I dug in my closet and found an original DVD with Outlook 2003 and a license I never bothered to install. I will test on a copy of my productive VM later on.
logies
Post by logies » Fri Jan 20, 2017 5:06 pm
I upgraded from Outlook 2002 to 2003 and EPIM Pro is offering import now. Import crashed on tasks after about 15 min (a few thousands tasks, I assume). 130 addresses were imported, missing 1-2. I compacted the Outlook 2002 database, then imported it to a new database in the format of Outlook 2003. Import from there crashed again, same error message, I believe. EssentialPIM offered sending an error report on both crashes, I agreed. But I`m running out of time now. Office is closed now, so I have only the weekend for migrating a lot of software and hardware vom a XP-VM to a Win10-VM. I will try with Outlook 2003 with Public Sharefolder, Mailenable, GPGRelay und Spambayes (the old configuration I hoped to get rid off) on Win 10. Going from there to somewhere has to wait.
What is happening on import with folders and subfolders (for tasks and email) from Outlook on EPIM Pro? Is the folder structure somehow preserved or is it lost?
logies
Post by logies » Sat Jan 21, 2017 1:45 pm
After stripping down my public.pst from about 40,000 items to 340 (only the active recurrent ones) import to EPIM was not a problem. I will try to continue with EPIM (just activated for further testing 4 licenses), because my old setup described above is much messier (and Public Sharefolder 1.5 did not want to show a public folder to Outlook 2003 on Win 10 Pro, but at least the fresh install of Outlook 2003 on the same machine as EPIM makes migration a bit easier). Folder structure of tasks is not preserved on importing (for emails it ist) so I have to export and import only parts of the old tasks tree structure per time for not loosing control.
