iCloud sync issue when contact has photo
If any contact has a photo added, iCloud synchronization hangs. If there is no photo on any contact everything works fine. A have already configure 2-factor authentications. Any suggest? Thanks for your help. Regards
Re: iCloud sync issue when contact has photo
please send us a log:
please enable extended logging in Tools-> Options-> Synchronization, perform the synchronization and then get log for faulty synchronization using Tools-> Options-> Synchronization-> Browse and send it to epimsupport@... describing the problem and with a link to this forum topic.
Thank you. Looks like a contact with a name "Lili" has a damaged photo. Please try to add photo once more. If that does not help, can you please send us the photo (to ma@essentialpim... with a link to this topic)
