EPIM Cloud Sync and links from calendar entries to contacts
Oil
Has thanked: 7 times
Post by Oil »
The last time I started the synchronization between my local Epim and the Epim Cloud, all links between the calendar entries and the contacts disappeared. :cry:
Is it now possible to synchronize without losing the links?
I would also be fine with synchronizing EPIM to Cloud (one-way) without losing the links.
Unfortunately I took the cloud directly for one year, but I can't use it like this.
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Re: EPIM Cloud Sync and links from calendar entries to contacts
Post by Trinitylab »
I agree that loosing links is absolutely terrible. We have kind of 600 internal stuff, Contact to Big Note, and once, during one update we lost it. Would take day or two of labour to recreate them.
Been thanked: 363 times
thank you for the report. We have re-run our tests and could not reproduce the issue.
Can you give us more information, maybe steps to reproduce it?
Trinitylab
I do not know if it helps, but we lost our links once, during a major update, probably 5-6.
