Error synchronizing outlook.com Calendar
steinj14
Post by steinj14 »
I'm getting an error when synchronizing my outlook.com Calendar with EPIM. The error message is "The specified object was not found in the store." (see screenshot).
Can anyone assist with this? I am using EssentialPIM Pro Portable version 8.63 on Windows 10 Home (64-bit). Thanks!
Re: Error synchronizing outlook.com Calendar
I would suggest deleting the synchronization from EPIM and creating it again. If that does not help, extended mail log would be needed: enable extended logging in Tools-> Options-> Synchronization, perform the synchronization and then get log for the synchronization using Tools-> Options-> Synchronization-> Browse and send it to epimsupport@... with a link to this forum topic.
steinj14
Post by steinj14 »
Followed your instructions and so far, so good. Thanks for your help!
