visualizzazione contatti
cf.epim
Post by cf.epim »
Buongiorno,
sto utilizzando Epim Pro Portable su un vecchio notebook Windows 10 che ha una risoluzione dello schermo 1024 x 600.
Va tutto bene tranne la schermata dei dettagli della rubrica perché i campi non vengono visualizzati per intero ma risultano troncati a destra (in pratica escono dallo schermo).
C'è un sistema per ovviare a questo inconveniente?
Grazie
Been thanked: 363 times
Re: visualizzazione contatti
it would be good to get a couple of screenshots demonstrating the issue.
cf.epim
Post by cf.epim »
Sorry I'm late, as you can see the fields to the right do not display completely.
Thank you
you can manually make the window larger and it will remember the size. If that's impossible due to small screen resolution- unfortunately nothing can be done from our side here. You can also decrease DPI setting of your Windows- that might allow to fit more data.
cf.epim
Post by cf.epim »
I tried but there is no way to view the fields completely.
No problem, this is a temporary notebook and will soon be replaced by a new one.
Thank you
