Salvataggio allegati in cartelle di rete
r.amendolara
Post by r.amendolara »
Ciao.
Ho provato a salvare un allegato in una cartella di rete (è su un server interno alla mia azienda). Pur avendo creato i collegamenti alla cartella sul desktop, non riesco a vederli e, di conseguenza, a salvarli.
Sbaglio qualcosa?
Rocco
Hi.
I've tried to save an attachment in a folder (stored in an internal server of my organisation). Despite having created a shortcut to the same folder on desktop, I'm not able to view it (see screenshot).
Is something got wrong?
Rocco
Been thanked: 363 times
Re: Salvataggio allegati in cartelle di rete
On the screenshot you see only Folders and Network drives, but not shortcuts. You can still select your Network drive and navigate to the folder on the Network drive. I think that's under "Rete" on your screenshot.
r.amendolara
It would be great if, in the next version of sw, the shortcuts will appear in the available option (in the 'save attachment' mode...).
Thanks for your reply.
Rocco
what is your Windows version? Can you also show on screenshot- where do you exactly click to get the file save dialog?
When I try save Attachment from Mail, I get this dialog (with shortcut to Network drive as you can see on screenshot):
