Сетевая версия
Moderators: SolA, vvorl
vano25602
Re: Сетевая версия
Post by vano25602 »
Дошпилил до мышей: что сделано - правка реестра
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\LanmanWorkstation\Parameters]
"ServiceDll"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,\
00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,\
77,00,6b,00,73,00,73,00,76,00,63,00,2e,00,64,00,6c,00,6c,00,00,00
"ServiceDllUnloadOnStop"=dword:00000001
"EnablePlainTextPassword"=dword:00000000
"EnableSecuritySignature"=dword:00000001
"RequireSecuritySignature"=dword:00000000
"AllowInsecureGuestAuth"=dword:00000001
"OtherDomains"=hex(7):00,00
включение потокового мультимедиа
подключилось и сразу выбило ошибку
Exception log with detailed tech info. Generated on 27.01.2021 8:27.
Application title: emp.epim - EssentialPIM Pro
Application file: C:\Program Files (x86)\EssentialPIM\EssentialPIM.exe
Application: EssentialPIM Pro 9.6.1 26.12.2020
Exception message: arithmetic exception, numeric overflow, or string truncation
string right truncation.
Exception address: 00777AF0
Main thread ID = 7920
Exception thread ID = 7920
Object Logs:
08:27:39.590 SetViewMode 0
08:27:39.365 DBOpen
08:20:43.840 DBClose OK
08:20:43.759 DBSave OK
08:20:43.730 DBSave
08:20:41.470 DBClose
08:19:59.045 DBOpen OK
08:19:59.009 SetViewMode OK
08:19:58.750 SetViewMode 0
08:19:58.450 DBOpen
08:27:39.750 MainForm
08:27:37.287 StatusForm
08:27:30.789 ConnectDialog GroupBox1 PasswordEd
08:27:18.790 ConnectDialog GroupBox1 LoginCB
08:26:41.290 ConnectDialog FileCB
08:26:36.780 ConnectDialog SelServerBtn
08:26:30.290 ConnectDialog ServerCB
08:26:18.780 ConnectDialog SelServerBtn
08:26:16.780 ConnectDialog ServerCB
08:24:43.690 MainForm
Memory: 3968; free 1260
Display: 1280x1024 pixels, 32 bpp, 96 PPI
Updates: 1
Last update: 26.01.2021
vano25602
Re: Сетевая версия
Post by vano25602 »
Andrey
Been thanked: 119 times
Re: Сетевая версия
Post by Andrey »
Это на новой базе?
vano25602
Re: Сетевая версия
Post by vano25602 »
Да на новой
Andrey
Re: Сетевая версия
Post by Andrey »
А при переключении между модулями потом ошибки есть?
vano25602
Re: Сетевая версия
Post by vano25602 »
Да есть, с базой невозможно работать
Andrey
Re: Сетевая версия
Post by Andrey »
Эту же базу на этом же компьютере открывает без ошибок?
vano25602
Re: Сетевая версия
Post by vano25602 »
Победил - по сути помогла правка реестра, переустановил Firebird все заработало. Теперь вопрос - безсрочная бизнес лицензия на сколько компьютеров?
Has thanked: 1411 times
Been thanked: 984 times
Re: Сетевая версия
Количество лицензий должно соответствовать количеству компьютеров, на которых будет установлена Бизнес версия. Бессрочная лицензия позволяет заплатить за программу один раз и неограниченное время получать все обновления бесплатно.
