Problema sincronizando Contacts con Google
sergioglezgala
Has thanked: 5 times
Post by sergioglezgala »
Cuando sincronizo los contactos con Google, pasados unos minutos me sale este mensaje de error:
"An invalid character was found in text content". Supongo que quiere decir que dentro de los contactos de EPIM he puesto algún caracter inválido. El problema es que no dice cuál es ese caracter. ¿Puedo conocer la lista de caracteres inválidos?
Sergio González Galarreta
Been thanked: 363 times
Re: Problema sincronizando Contacts con Google
please go to File-> Database Management-> Clear Google Cache, it may help.
sergioglezgala
I am sorry, it does not work.
Then something is wrong with your Contacts. Try to synchronize an Empty database with your Google Calendar. If it works, then the problem is in database, we can check it if you send it to ma@essentialpim...
sergioglezgala
I am still in 4.51. Should I download 4.53 from the web or is there any upgrade package?
sergioglezgala
I have synchronized an Empty database with my Google Calendar and it worked fine. I send you my database to ma@essentialpim
sergioglezgala
My db is 17 Mb. Thunderbird has problems sending you that file. Is there any other way?
sergioglezgala wrote:I am still in 4.51. Should I download 4.53 from the web or is there any upgrade package?
you should download from http://www.essentialpim.com/?r=download
sergioglezgala wrote:My db is 17 Mb. Thunderbird has problems sending you that file. Is there any other way?
Try to pack it (zip it). It will reduce the file greatly
sergioglezgala
Hello. I already sent you the file. Have you received it?
sergioglezgala
Hi. Have you received my file?
sergioglezgala
sergioglezgala
Is anybody in charge of this problem, please?
Is anybody going to answer anything, please?
yes, we received your file. PLease check latest 4.54, will it have the problem?
sergioglezgala
I am sorry, still the same.
