Pop up reminder/alert
Delboy
Post by Delboy »
Is there any way I can ensure that the reminder/alert box is on top of anything else that's open on my desktop ?
I'm using the free version on Win7 Home premium edition.
Ta,
Del.
Delboy
Re: Pop up reminder/alert
Post by Delboy »
Can anyone even suggest a work around please ?
Derek.
Been thanked: 363 times
it is not clear what you need. You mean that Reminder does not appear on top of other windows when it appears, OR, you want reminder to stay on top if you switch to another program?
Delboy
Post by Delboy »
Yes, basically,If I have another program open such as a speadsheet or the web browser open across my desktop the pop up alert/reminder box does not show as it is hidden by whatever is open on the desktop.
Cheers,
Del.
Scotty
Been thanked: 15 times
Post by Scotty »
I fairness, when there is an alert, EPIM opens an alert window that flashes on the program taskbar a the bottom of the screen.
Delboy
Post by Delboy »
Yes It does flash but not very obviously and only for a short period, same as the new mail task bar notification.
