Export to exe (ebook file)
senerh
Post by senerh »
I would like to see an option to be able to export my database including contacts etc to a one EXE file. just like TtreeDB notes or My Notes Keeper.
So I can share my ebook in the original format as an ebook for example.
Would be great if possible to be able to choose which Pane to export as exe file, for example if I wantl to share only my Contacts, I would choose export to exe file and choose only for Contacts...
Thanks,
Sener.
Been thanked: 363 times
Re: Export to exe (ebook file)
thank you, suggestion noted.
emails4me
Post by emails4me »
As a consultant, I store a lot of notes. I use a different tool for creating EXE ebooks for documentation of the completed work instead of using Word. Its much more polished since it will include the search capabilities, attachments, etc. from the application.
This suggestion was posted way back in 2013, is there any intention for this feature in the near future ?
