EPIM Online
EPIM Online
It would be great if I could log online from any computer to use EPIM software in a cloud with a browser. You could expand your market because online software works for all operating systems. It would also benefit EPIM because you could charge an annual fee.
Re: EPIM Online
thank you for the suggestion. We have a partial solution- EPIM Cloud, that is used mostly to synchronize 2 EPIM copies between themselves, but also has a limited web interface. So far we are thinking about the idea of expanding it.
Re: EPIM Online
This is something I would definitely use. A lot of people use Google Calendar and are looking for apps that sync. With EPIM online, they'd have all of that in an online app. EPIM as it is now is too slow for my purposes. The sync is clunky and I budget my weeks in Google Calendar which creates a lot of repeated events that Google Calendar handles well but EPIM doesn't due to the nature of the software. Again, would love to see a online version of EPIM.
- Been thanked: 15 times
Re: EPIM Online
Sounds like what you really want isn't EPIM at all, but rather NextCloud.Joel1245 wrote:This is something I would definitely use. A lot of people use Google Calendar and are looking for apps that sync. With EPIM online, they'd have all of that in an online app. EPIM as it is now is too slow for my purposes. The sync is clunky and I budget my weeks in Google Calendar which creates a lot of repeated events that Google Calendar handles well but EPIM doesn't due to the nature of the software. Again, would love to see a online version of EPIM.
Re: EPIM Online
Actually, it very well may be. I'll take a look at it as I wasn't aware of NextCloud. Thanks Dumble...er.....TumbleDoor!TumbleDoor wrote:Sounds like what you really want isn't EPIM at all, but rather NextCloud.
- Has thanked: 16 times
- Been thanked: 41 times
Re: EPIM Online
Is there any guide on how to setup Nextcloud to be sync with Epim Pro?
- Been thanked: 11 times
Re: EPIM Online
I have tried EPIM Cloud multiple times in the past. There have been a number of improvements with the sync and for me it is working good so far and I am transferring alot of data. I am mainly using it to sync between a desktop and a Surface. I would agree that if we could also sync to an android or IOS app then it would be complete and we would no longer have any reliance on a 3rd party. For my android I am currently using the PC sync with the EPIM app and it works fine. However, it would be great to have that as a cloud sync with EPIM servers.
Re: EPIM Online
It should be as simple as clicking on File->Synchronization->Add Synchronization->ownCloud, NextCloud and following the on screen instructions of the synchronization wizard.Trinitylab wrote: ↑Wed Jun 16, 2021 9:18 am Is there any guide on how to setup Nextcloud to be sync with Epim Pro?
DavidN, this feature is in the plans, thanks!
Re: EPIM Online
Thank you, admin, Epim part is easy, but I getadmin wrote: ↑Wed Jun 16, 2021 8:43 pmIt should be as simple as clicking on File->Synchronization->Add Synchronization->ownCloud, NextCloud and following the on screen instructions of the synchronization wizard.Trinitylab wrote: ↑Wed Jun 16, 2021 9:18 am Is there any guide on how to setup Nextcloud to be sync with Epim Pro?
"Error discovering the NextCloud end-points. Please check if you have a correct working setup."
So I do not know what is a correct working setup for Epim.
Re: EPIM Online
The error says it all. The NextCloud server needs to be configured correctly so that EPIM could get endpoints for data sync.
Re: EPIM Online
Thank you, admin, yes, I can figure it out.
What method does the sync with Nextcloud use, CalDav?
Re: EPIM Online
Yep, all the DAV type of protocols: CalDAV, CardDAV, WebDAV.
- Frizzell9
- Has thanked: 30 times
Re: EPIM Online
Now would be a really ideal time to expand on EPIM Cloud and compete with big tech, as every day hundreds of Google users have chosen to no longer support Google by using any of its products and allowing their information to be monitored.
Frizzell9
EPIM Pro User Since 2006
Re: EPIM Online
Thanks for your note, will consider it.
Re: EPIM Online
To me the desktop EssentialPIM application is perfect, since my preference is to keep all of my data private, and I can carry it encrypted on a usb stick. Users have the option of putting their data online if they want to.
