Font size on android device
Golfy
Has thanked: 9 times
Been thanked: 13 times
Post by Golfy » Wed May 25, 2016 7:38 pm
as I'm the french translator (up to now but if someone would to spend some time to help me, I would thanks him :wink: ) a customer send me an email to have an enhancement :
He would to have ability to increase font size on his android PAD (not smartphone but big screen android device). He's using PC EPIM and Android version.
So, I've translated his request here :D
Has thanked: 531 times
Been thanked: 307 times
Re: Font size on android device
Post by admin » Thu May 26, 2016 6:33 am
Golfy, thanks for letting us know about the request. Do you happen to know which module specifically did the user mean? You can change font size in Notes in the latest 4.1.5 version, will that be enough?
Golfy
Post by Golfy » Thu May 26, 2016 10:24 am
Unfortunaly not. The user want to change font size in calendar :
Bonjour,
J'utilise sur mon fixe et sur ma tablette l'application EssentialPim.
Sur la tablette, je trouve que cela serait un plus si la police utilisée dans le calendrier pouvait être un peu plus grande ou réglable par l'utilisateur.
La police utilisée est vraiment petite et difficile à lire par des yeux d' un septuagénaire ;-)
Merci pour votre attention et bonne continuation avec ces applications très utiles.
Salutations, Marc B.
Thanks to take care about his problem :)
Post by admin » Thu May 26, 2016 3:58 pm
Thanks for the update, will take the suggestion into account as we move forward with product development.
Doreen
Post by Doreen » Thu Aug 11, 2016 11:33 am
Using this post for joining the suggestions/requests for the Android app:
As a freelancer I am currently searching for a cross-platform calendar with task management (incl. adding deadlines with time) that may be synchronised without cloud. EssentialPIM Pro actually does offer all the functions I am searching for, but is missing some (for me very important) options, that I love in BusinessCalendar2 (unfortunately it's not possible to import/export tasks to other tools there):
- change the font size in the app/widgets
- change the general size (i.e. see the whole day/week from 0:00 - 0:00 without scrolling)
- add a widget to the home screen showing the week (and maybe even browsing past and future weeks)
If these could be added with future versions, I'd readily switch.
Post by admin » Thu Aug 11, 2016 3:21 pm
Thanks for the suggestions, noted.
