Appointment/Task reminder window GUI improvement
matsch
Post by matsch »
In the Appointment/Task reminder window clicking inside the window should select the first in the list or at least when there is only one to select this one.
Also one should not be able to change the "remind in" time while no reminder is selected. Which is the case at the moment: nothing is selected then you change the time and then select the item in the list of reminder and the time you selected is lost
Thanks in advance
M
Re: Appointment/Task reminder window GUI improvement
thank you. Agree with the second suggestion, while the first one will need some investigation work.
matsch
Post by matsch »
3 years later the problem is still here... a minor GUI
Has thanked: 1411 times
Been thanked: 984 times
Will try to address both of these suggestions in the next update.
