- 2017-11-06_092114.png (10.16 KiB) Viewed 555 times
Roll-up button on sticky note is hard to see once used.
Once used the roll-up button becomes a very hard to see light blue.
Re: Roll-up button on sticky note is hard to see once used.
That depends on the background color mostly.. However, will think about making selected icons better visible on the darker backgrounds. Thanks!
