Sometimes, an e-mail doesn't get sent properly - e.g. server problems, or a problem with the recipient's mailbox which results in non-delivery.
It'd be nice to be able to re-send (or even edit+resend) an e-mail. Even if that email appears again in the Sent Items folder.
"Send Again" option
Re: "Send Again" option
I solve this problem simply by go to "sent" folder, click on "forward" delete the double signature and send is again. You only have to type in the recipient mailadress again.
thank you, suggestion noted, however, a8907433's suggestion should work fine, I think.
Sure, that works, but it's a bit of a dog of a way around... I'll use it for now, but I'd consider it a "workaround" rather than a fix...
Cheers!
Ade.
Cheers!
Ade.
