Zoom text in notes.
FireBrand2026
Been thanked: 7 times
Zoom text in notes.
Post by FireBrand2026 »
Having just upgraded to a high DPI display the lack of zoom in notes is quite noticeable.
I could go though by hand and change all the notes sizes, but besides being unreasonable that would also effect how things print witch would be unacceptable.
Emails zoom as expected, so my suggestion would be to simply add the same zooming ability for notes as there is for emails.
Rose Ford
Been thanked: 16 times
Re: Zoom text in notes.
Post by Rose Ford »
+ Here as well, finally decided to upgrade my ancient screen to a 4k models today and notes in EPIM are now pretty much un-readable.
Not sure what I'll do about it either other than hope a zoom gets added sooner rather than later.
ecsaltz
Has thanked: 23 times
Been thanked: 37 times
Post by ecsaltz »
I have 3, 28" 4K monitors on a PC running Win10.
I have no problem reading notes in EPIM, and believe me, my eyesight is barely corrected. All one needs to do is to go into options and set the default font size for notes. At least for me, that works very well. Hope that works for everyone else, too.
Now, for old notes written on a previous low resolution monitor, one could "select all" and use a font style to change the notes' size. This works well ofr me, although it's a problem if the original note had different font sizes to begin with.
PC Desktop: Window 10 Pro, three 4K monitor extended display system.
Cell phone: Verizon Wireless Samsung Note 8, Android 8 - linked with Samsung Gear 3 watch and original Pebble watch.
Rose Ford
Post by Rose Ford »
ecsaltz wrote:
Sun May 06, 2018 3:49 am
As mentioned by the first poster that doesn't work if you are printing off notes for office work.
You can set a default font size, which is than going to print at that size...
Which is why so many text editors have zoom, and not just font size.
FireBrand2026
On top of what's already been said about printing issues. Increasing the default font size, also creates issues for rich copy/past and shearing exported notes with other people.
Also worth noting as someone who uses the Business/network version as well resorting to that would create issues for other clients as well, as it's quite common for different people to have different screen setups.
TumbleDoor
Been thanked: 11 times
Post by TumbleDoor »
+1 another major issue with no note zoom is hampering portability. Yesterday I tried to use my normally always handy portable EPIM on a 24" 4K screen at a coworkers house and it was pretty horrible.
I also have to agree that even if you are using EPIM on only a single system changing the default font size to something besides a standard print size is probably asking for long term trouble.
ecsaltz
Post by ecsaltz »
Rose Ford wrote:
Tue May 08, 2018 11:49 pm
I see your point in printing. I use a very popular text editor, UltraEdit, and I can set screen and print font sizes independently. I can see your point, and having zoom would make sense for EPIM.
DG
Beta Team
Been thanked: 5 times
Post by DG »
+1 for zoom in notes.
Regards,
DG
Been thanked: 363 times
thank you for your posts. We will look into this.
flesym
Post by flesym »
Any news regarding this topic?
so far that has not been implemented.
flesym
Post by flesym »
Max wrote:
Thu May 14, 2020 12:34 am
This is the only reason I am not using / buying the software as many of my colleagues use it and I love the concept. It would also make my life easier because of note sharing for documentation purposes.
Is there any time estimate / prediction for implementing this feature?
Thanks in advance
SilverSound
Post by SilverSound »
+1 Zooming in notes would be a much appreciated feature
