Basically this is an additional suggestion for To-Do's.
Bear in mind that these are nice to have's:
1. A custom sorting option for to-do's. E.g. Sort By: Category, Priority, Subject
2. A way to collapse / expand the Tree in the To-Do list to only show the parent and not the children like you have the option in Windows Explorer when you click on the [+] and [-] next to the directory.
Regards,
Chris
To Do or Not To Do - What is the question?
This is my free news ticker software. that allows you to subscribe to any RSS feed you want.
Re: To Do or Not To Do - What is the question?
Hello Chris,
Isn't sorting performed when you click on a column name in To-Do main view?Chris wrote:1. A custom sorting option for to-do's. E.g. Sort By: Category, Priority, Subject
Isn't it shown when you Click on "Table" (on the right pane) in To-Do main view?Chris wrote: 2. A way to collapse / expand the Tree in the To-Do list to only show the parent and not the children like you have the option in Windows Explorer when you click on the [+] and [-] next to the directory.
Hi Max,
Been away for a few days ... anyway
- Parent 1
|---P 1 Child 1
|---P 1 Child 2
-Parent 2
|- Par 2 Child 1
| |--- Par 2 Child 1 Sub 1
| |--- Par 2 Child 1 Sub 2
If you use table, you get a list like this:
Parent 1
Child 1
Child 2
Parent 2
Par 2 Child 1
Par 2 Child 1 Sub 1
Par 2 Child 1 Sub 2
What I was asking for was TreeView functionality like this:
+ Parent 1
+ Parent 2
So you can see only the Parent tasks.
Regards,
Chris
My mistake here, what I meant is: Sort By: Category Then Priority Then Subject.Max wrote: Isn't sorting performed when you click on a column name in To-Do main view?
No, unfortunately when you click on "Table" view you get a flat list of all your ToDo's (Parent and Children). LFor example, my Todo Tree looks like this:Max wrote: Isn't it shown when you Click on "Table" (on the right pane) in To-Do main view?
- Parent 1
|---P 1 Child 1
|---P 1 Child 2
-Parent 2
|- Par 2 Child 1
Parent 1
Child 1
Child 2
Parent 2
Par 2 Child 1
Par 2 Child 1 Sub 1
Par 2 Child 1 Sub 2
+ Parent 1
+ Parent 2
Regards,
Chris
Hi Chris,
I see. Yes, that's planned, multiple sorting.Chris wrote:Chris wrote:1. A custom sorting option for to-do's. E.g. Sort By: Category, Priority, SubjectMy mistake here, what I meant is: Sort By: Category Then Priority Then Subject.Max wrote: Isn't sorting performed when you click on a column name in To-Do main view?
I see now. That's also in the plans, but will require a whole remake of To-Do module.Chris wrote:Chris wrote: 2. A way to collapse / expand the Tree in the To-Do list to only show the parent and not the children like you have the option in Windows Explorer when you click on the [+] and [-] next to the directory.No, unfortunately when you click on "Table" view you get a flat list of all your ToDo's (Parent and Children). LFor example, my Todo Tree looks like this:Max wrote: Isn't it shown when you Click on "Table" (on the right pane) in To-Do main view?
- Parent 1
|---P 1 Child 1
|---P 1 Child 2
-Parent 2
|- Par 2 Child 1
Parent 1
Child 1
Child 2
Parent 2
Par 2 Child 1
Par 2 Child 1 Sub 1
Par 2 Child 1 Sub 2
+ Parent 1
+ Parent 2
Regards,
Chris
Remake - ouch!
That it is in the plans: Great!
Thanks Max
Thanks Max
