Highlight Code
emails4me
Highlight Code
Post by emails4me »
I guess there are a lot developers or sysadmins who use EPIM to save notes and code.
Viewing code in plain text is hard to read. Would be great if there was support to highlight code. Perhaps using keyword syntax list from other programs eg. Ultraedit or perhaps include some of the popular languages
tahoma
Been thanked: 8 times
Re: Highlight Code
Post by tahoma »
That might be a great, but you might find that many source code editors (for instance MS Visual Studio) allow you to copy the syntax highlighted code. You can than paste it into a EPIM Note, keeping the syntax highlighted code exactly the way that you work with it (No hassle with defining the syntax and colours in EPIM). At least one text editor can do this too (EditPadPro). I don't know about Ultraedit...
emails4me
Re: Highlight Code
Post by emails4me »
Yes, know that trick, but its inconvenient and relies on other applications.
There are other note taking apps (eg. RightNote) that have this feature embedded in their application without relying on VS or other editors. Would be good to see this feature in EPIM.
Has thanked: 779 times
Been thanked: 411 times
Re: Highlight Code
Thanks for the suggestion, noted!
