EssentialPIM submenu EpimToday Go to the element
beni
Has thanked: 4 times
Post by beni »
Is it possible to change the application so as to have in the context menu,
for a task present in "Epim Today", a submenu "Go to the elemen"t. And display the task as in the screenshot (with the task tree) ?
Been thanked: 363 times
Re: EssentialPIM submenu EpimToday Go to the element
thank you, suggestion is clear. Why would you need it and how you would use it?
beni
Post by beni »
When I double click, the application only opens a window on the element itself, which is very good.
But if I want to know where this element is in all the information that we manage then we cannot find it easily.
Whereas with the "go to the element" function, we immediately find all the related elements. Besides, this function exists elsewhere in the application.
It would just be enough to add it everywhere in all the contextual menus of the application.
Thanks for your feedback.
