Import HTML
lbw2112
Has thanked: 4 times
Import HTML
Post by lbw2112 »
I remembered reading this in some threads and when searched the only thing I found was a few years old.
Is there anything in the future planned for HTML import?
Thanks,
Larry
Been thanked: 363 times
Re: Import HTML
where exactly you would like to import the HTML? Also, what would be the source of this HTML?
lbw2112
Re: Import HTML
Post by lbw2112 »
Importing HTML into the Notes Module. Sorry about leaving that out.
The HJT and RTF import works perfectly but I get a lot of notes that are HTM from some outliners that only export that format. InfoQube would probably be the main one. As it is now I Import the HTM files into another Information Manager and then export them into HJT or RTF to import into EPIM. Pretty easy that way actually but thought I'd ask when remembered reading about it in the forum a while ago.
Thanks,
Larry
