Add "Go To Item" to Tags Explorer
lbw2112
Has thanked: 4 times
Post by lbw2112 »
Add "Go to Item" to Right Click Menu when you right click on an Item in the list in the Tags Explorer.
The "Go to Item" in the Advanced Search works good and is easy to get to the Item searched for, having the same thing in Tags Explorer would help a lot in case I need to modify the title or just select the item.
Thanks,
Larry
Has thanked: 779 times
Been thanked: 411 times
Re: Add "Go To Item" to Tags Explorer
Thanks for the suggestion, will do that in one the coming versions.
