EPIM Pro 64 bits to access MAPI 64 bits to sync Outlook 64 bits
Laurent C.
Post by Laurent C. »
Hi
Windows 64 bits is the rule :!:
The Office 2019 64 bits is more and more often a choice for these reasons :
https://support.microsoft.com/en-us/off ... n-us&ad=us
https://support.microsoft.com/fr-fr/off ... r-fr&ad=fr
Do you intend to offer syncing with Notes, Tasks, Calendar ... using the MAPI 64 bits instead of the separated tool named EPIM-Outlook Sync ? (not emails with IMAP trick) :
https://www.essentialpim.com/pc-version ... ntary-apps
It seems from Microsoft that the MAPI 64 bits is really easy :
https://docs.microsoft.com/en-us/office ... dfrom=MSDN
:?: 32-bit MAPI application and 64-bit Outlook
:arrow: 32-bit MAPI applications are not supported to run on a computer installed with 64-bit Outlook and 64-bit Windows. The application developer must update and rebuild the application as a 64-bit application for the 64-bit platform. This is because a 32-bit application cannot load a 64-bit Msmapi32.dll file. There are a small number of API changes that application developers must incorporate to build their code successfully for a 64-bit environment. MAPI header files have been updated with these changes to support the 64-bit platform. You can download these header files at Outlook 2010: MAPI Header Files. Developers can use this same set of MAPI header files to build both 32-bit and 64-bit MAPI applications.
https://docs.microsoft.com/fr-fr/office ... dfrom=MSDN
:?: Application MAPI 32 bits et Outlook 64 bits
:arrow: Les applications MAPI 32 bits ne peuvent pas s’exécuter sur un ordinateur sur lequel sont installés Outlook 64 bits et Windows 64 bits. Le développeur d’applications doit mettre à jour et reconstruire l’application comme une application 64 bits pour la plateforme 64 bits. En effet, une application 32 bits ne peut pas charger un fichier Msmapi32.dll 64 bits. Les développeurs d’applications doivent incorporer un petit nombre de modifications d’API pour créer leur code pour un environnement 64 bits. Les fichiers d’en-tête MAPI ont été mis à jour avec ces modifications pour prendre en charge la plateforme 64 bits. Vous pouvez télécharger ces fichiers d’en-tête en vous reportant à la rubrique relative à Outlook 2010 : fichiers d’en-tête MAPI. Les développeurs peuvent utiliser ce même ensemble de fichiers d’en-tête MAPI pour créer des applications MAPI 32 bits et 64 bits.
The 64 bits Office applications are there since Office 2010, 2013, 2016, 2019...
Regards
Win Pro 64 FR / EPIM Pro + Office Pro 2010 / CPU Ryzen 9 3950X / GPU RTX 2080 Ti / SSD 2TB PCie 4.0 / RAM 32GB DDR4-3600
Laurent C.
Re: EPIM Pro 64 bits to access MAPI 64 bits to sync Outlook 64 bits
Added English references versions...
Laurent C.
Hi
Just no answer at all, I see... :(
I do not understand why there is not an EPIM 64 bits version for Outlook 64 bits as all editors proceed now ?
EPIM forced me to install Outlook 32 bits and that means I'm forced to use all the Office 32 bits because it is not possible to mix 32/64 bits !
So, I'm stuck with Excel 32 bits limitations...
Regards
Has thanked: 778 times
Been thanked: 409 times
Why don't you use EPIM-Outlook Sync if you wish to sync with the 64-bit edition of Outlook?
Laurent C.
Hi
I do not want to sync everything
And, I want to choose Notes, Contacts from different PST files and both ways or not and deletion or not with synchronization in the background each 15 minutes, etc ...
Regards
You can do all that with EPIM-Outlook Sync, except for the scheduled synchronizations, unfortunately.
Laurent C.
Except for the scheduled synchronizations, unfortunately : yep, and this is the most important feature besides the fact to just have EPIM simply running as for the Outlook 32 bits use case... :wink:
Laurent C.
I have installed Office 2019 Pro 32 bits ; the hand forced by EPIM ; somewhere it's pitiful... :cry:
Please elaborate about your use case scenario. Why would you need scheduled syncs directly with Outlook?
Laurent C.
As an example, I sync some "out of the cloud" notes every 15 minutes between Outlook PC - EPIM PC - EPIM Android to have them on my mobile and vice-versa...
