First check if item is "attached" (related) before deleting/modifying
r0n
Post by r0n »
I was testing epim and found out that if you "attach" (related items) an email to a note, deleting the email also deletes the email "attachment" (related items) in the note.
I do not know if there is something I have missed and if this is an issue that exists across the board.
Meaning: Does this issue also persist within task, calendar,...?
It would be user friendly, if the user was first notified that the item you are trying to delete/modify is "attached" (related) to another item.
Re: First check if item is "attached" (related) before deleting/modifying
Thank you for the suggestion, it is noted.
