Dual pane note view
SilverSound
Dual pane note view
Post by SilverSound »
I often keep my main documents on leaf 1 and then use leaf 2 for important notes.
It would be handy if there was a view mode were I could edit both leafs at the same time.
Example:
MetalDrop
Been thanked: 158 times
Re: Dual pane note view
Post by MetalDrop »
+1 I would get a lot of use out of being able to edit two leafs at one time.
EPIM Portable Pro on Windows 10 Pro 64-bit US-ENG, Intel i7 7700k, 32GB DDR4, Nvidia 970 & AMD Ryzen 2600 16GB DDR4 Nvidia 1080ti.
[I'm helpful and often reply to questions, please note however I am just a fellow user and not staff.]
DG
Beta Team
Been thanked: 8 times
Post by DG »
+1 I use leaves similar to SilverSound.
Rose Ford
Been thanked: 19 times
Post by Rose Ford »
+1 70% of my notes are setup in a way were being able have dual pane two leaves would be an amazing feature.
mihalvld
Been thanked: 5 times
Post by mihalvld »
+1. Nice suggestion.
EPIM Pro Portable 9.7 / Windows 7, 10
S_Belle
Post by S_Belle »
+1 I would love this as long as the two panes sizes where adjustable and not fixed at 50/50.
My second leaf's are todo list and quick point information so I only need them to take up 20% of the screen.
FireBrand2026
Post by FireBrand2026 »
+1 I'd find this quite a useful time savor and a great use for my bigger monitor. I avoid using EPIM in full screen since then the note area gets too massive, being able to split it into two panes though would be great.
TumbleDoor
Been thanked: 13 times
Post by TumbleDoor »
+1 I frequently need to reference things on a second leaf and tend to always have a popup editor open so I can see it to the side of the main window. This would simplify my habit greatly.
Has thanked: 901 times
Been thanked: 520 times
Thanks very much for the suggestion and for your reactions to it. Noted!
