Notes category ?
dirmansyah
Notes category ?
Post by dirmansyah »
I can not find a way to set a category to a note-item.
Does note-item have a category? (using the same category table as the calendar-item and task-item use)?
If not, what is the reason?
(Trying to understand how the feature "Convert" works leads me to the above question.)
DavidN
Has thanked: 8 times
Re: Notes category ?
Post by DavidN »
I do not believe categories are a function of notes. For notes you would have parent, sibling and child notes and then leaf's within each note and they could then be filtered by tags. I may be incorrect here, but that is my assumption.
Been thanked: 445 times
It's true, there's no categories in Notes as of yet.
