I have requested this in another way in a previous post. It would be great to be able to have a short cut to archive a message and determine the location of the message.
For example: Select the message and hit Ctrl+E and it move the message to a folder.
I believe this would greatly help in productivity rather then clicking and dragging a message.
Archive Shortcut Key
- Has thanked: 1412 times
Re: Archive Shortcut Key
This one should be relativity easy to implement. Will see if we're able to do that in the next version already.
- Has thanked: 16 times
- Been thanked: 11 times
Hello, thank you for your consideration. Is this still an option to add to an upcoming release? This is a huge time saver. I am not an advocate for Outlook, however, this is a feature that they employ that is a huge time saver for archiving messages.
Not for for the upcoming version, unfortunately. Although, you'll be able to quickly move/copy messages to a list of last used mail folders through context menu in EPIM 9.6.
Looking forward to learning more about the context menu. Is 9.6 coming soon? Also, would I be able to activate the context with a shortcut key? If so that would help greatly.
It was released today You will not be able to use a shortcut key as you need to select a folder where to move/copy the selected message(s) into.
