Extensible dropdowns...
bobmac1547
Post by bobmac1547 »
Hey Max...
My list of categories is quite extensive. Each time I have to select one from the list, I have to scroll down. This happens time and time again.
My suggestion is that you make dropdowns extensible as shown in the attached image (which I captured from OneNote). I have circled the control that the user can grab with the mouse to make the list longer.
This could make things easier in a lot of scenarios.
I can explain in more detail if you would like...
Been thanked: 445 times
Re: Extensible dropdowns...
Got your point, thanks. Do you mean the list of categories that's in a separate new appointment/task window?
bobmac1547
Yes: in the separate new appointment/task window as well as the tree view of tasks (screenshot attached)
Understood, thanks!
