Here is the note module layout I like. Another popular note app implements this layout.
Happy New Year !
The following I made with spreadsheet
One more useless step. You can use the tabs (leafs) for such functionality.
Optional sounds really good! And where can I disable the new separated word search feature in the notes? It hangs when you paste a long search string in a quick search field and forget to wrap it with quotes.
